Configures the minimum TCP header allowed.
| size | Specifies the size of the header in bytes. |
| slot | Specifies the slot to be used. |
| all | Specifies all IP addresses, or all IP addresses in a particular state. |
The default value is 20 bytes.
This command configures the minimum TCP header allowed. It takes effect for both IPv4 and IPv6 TCP packets.
The range of the minimum TCP header may be between 8 and 255 bytes.
This command was first available in ExtremeXOS 12.0.
